I can cut dovetails every which way but loose but am having a hard time figuring out the technique for cutting this one. Any one got any advice?
Dovetails as usual in the center portion and mitered the rest of the way.
hd,
If I recall correctly, Christian Becksvoort wrote an article in FWW sometime in the last 2 or 3 years about those, they are called mitered dovetails. Someone should remember which article that was in.
Lee
Here you go hgdis,
see attached pic.
Cheers,
eddie
(avoiding work)
No mitered edges? LOL.. You picked a good one to start with!
I have made just a few.. To much work...
In two words I'd say 'Be Patient'.. I'm not patient so I do not do it unless requested.
Actually, it is not that hard BUT I find that if I'm not REALLY careful I mess up the sharp edge somehow?
Not sure that helps BUT you are not alone!
I did find that if I clamped a scrap of really hard hardwood at the edge for a backer block it helped ALOT!
hdgis,
I build a candlebox for Old Salem, in NC that has a similar joint. I'm a pins first kinda guy, so I cut the pins, then the miter on the pin side of the box, cutting it to just leave the scribe mark from the dovetail layout showing-just barely. Then cut the tails, and by trial and error, creep up on a good fit with the 2d half of the miter. I do the boxes in multiples, so I'm mitering the components in batches; using a stop block to regulate the setting for cutting the miters. Once it's locked in, bob's yer uncle.
Whats the fastest way to cut the mitres? Ive got 400 bracket feet to make and need to get em done quick! Thanks for pics.
Are these hand cut dovetails, with 400 I assume not? I did this for my humidor, but those were hand cut and the miters were cut with a handsaw and fit with a chisel. If they are machine cut, try doing a miter set up on your table saw with a good miter gauge with stop blocks to make it accurate and repeatable. That would be the only way I could think of doing it. Maybe others have ideas
Aaron
hdgis,
As Aaron has said, tablesaw, miter jig, and stop blocks. I only do 12-18 boxes at a time, so the miters go pretty quickly. Don't have any pictures, sorry. A picture of the box is on my website, http://www.davidraypine.com
