I was finishing up(No pun intended) a cherry piece. I had put on the 3rd coat of General Wipe on satin oil/poly. My brother can behind me and mistakenly covered that with a coat of Waterlox Oil finish. What are the consequences of this combination? Do I have to try and remove the oil somehow? The poly was on the piece for 2 days before the oil was put on.
Pam
I am not an expert on these brands (or any other) but have you read the label of the Waterlox? I would sort of guess that it is a varnish/oil mixture probably very similar to the first coat you applied. Check and see if it contains varnish.
