I often make my own wood filler (for filling small holes, etc.), by mixing some sawdust with glue. The other day I was filling some small holes in some purpleheart wood, so I made some purpleheart saw dust using a very fine saw blade, and mixed it with some Titebond glue. The mixture gets hard and sands well, but the problem is that the glue turns the mixture a dark gray color. I have tried clear-drying glue, and it still turns the mixture dark gray. The question for you is, what glue should I use so the mixture retains the color of the sawdust ? I read all the time that you can make your own wood filler by “mixing saw dust with glue”. I have tried lots of different glues, and they all turn the mixture dark. I appreciate any light you can shed on this problem!
Hi Thomas.
Andy Rae recently tackeled a similar question in his expert folder and we made a short article out of his answer. In short, he uses a mixutre of shellac and wood dust.
http://www.taunton.com/finewoodworking/Community/QADetail.aspx?id=28776
Alternatively, I've had the best luck filling dings and gaps with shellac burn-in sticks. You can buy these in a multitude of colors, which can be mixed, and they are easy to apply and sand smooth.
To tell you that truth, I've never had much luck matching colors with wood dust and glue mixtures unless they're standard browns and tans, which is not the case with purpleheart.
Matt Berger
Fine Woodworking
Thomas- you might also want to consider using black colored epoxy- See my answer ealier today on epoxy with Claro walnut. I have not tried to make a filler for purpleheart- but I would expect you would have a lot of problems matching because the color of purple heart changes so much as it oxidizes with age. It starts a brilliant purple and then usually mellows to a rich brown- I would not expect any glue/sawdust mixture to oxidize the same as the natural wood. If you look closely at the purple heart I am sure you will see some black spots and streaks here and there. Give it a try on some scrap.
Bob Van Dyke
