All,
I recently purchased a 1940’s band saw and would like to put it on a mobile base. I’ve looked around some but the weight rating for what I saw was lower than what is needed. I need one rated for at least 1000 lbs.
Does anyone have a link that I could follow?
dlb
Jet makes two bases (600 & 1200lb.) They are very easy to assemble with the use of spring loaded locating pins. Available @ http://www.eagleamerica.com
In the search box type in mobile base.
Bruce S.
Thanks! I'll look into it.
dlb
The undisciplined life is not worth examining.
I recently put a set of Zambus casters on a MM16 (around 600 Lbs). They're without a doubt the smoothest rolling thing in my shop which includes HTC, Powermatic, ShopFox, and Performax mobile bases or casters. They worth every penny and only slightly more money for a set of 4 than a mobile base. If you've got a place where you can mount these on the saw base, they have several models that would more than support the 1000 Lb load.
http://www.zambus.com/index.htm
If you build it he will come.
