What material can I use to make a mock up of a dovetail?
practice wood
I often use poplar as a "practice" or prototype material. It's inexpensive and works easily. For dovetails, however, softer woods behave differently than harder species - particularly at the fitting stage. So, it may be worthwhile to spend the extra money on using the target species.
The thing is I try a several times, and it still not good. That is why I wanted to make a mock-up, with something different then wood... give me some suggestions. I am really new to woodworking and this is my first try with dovetails. Thank you for your help.
dovetail practice
I'd start with poplar to practice your dovetail cutting. For me, the "breakthrough" came with better marking technique and learning to cut to the line while keeping the saw oriented properly. I use a marking knife that is flat on one side, so the flat side can be butted against the flat of the marking guide, thus creating a very precise line. Whether you use a western "push-style" saw or a Japanese pull-style Dozuki, or some other marking method, keeping things consistent helps. Think about the methods at the macro level, so you can visualize what is going on, and how marking method 1 dictates a corresponding cutting method.
Once you are getting consistent results with poplar, graduate to a "real" hardwood, so you can see the difference.
