Does anyone have FWW copy No.53 which has home built moisture meter? I would like the article if possible. Is there another moisture meter plan out there?
A moisture meter is basically a multimeter. It's the calibration and time to develop the list of species and readings that will be difficult. Learn how to oven dry to get a moisture reading. Being too cheap will get you in the long run. There's some really inexpensive meters out there.
I have a moisture meter , Timber Check, from Lee Valley Tools. It costs a little over a $100 with delivery. This is the only moisture meter I've used ( http://www.leevalley.com/wood/page.aspx?c=1&p=32548&cat=1,43513 ). I interested in opinions from those who own other moisture meters out there.
Timber check is quite simple and sturdy but I don't have a clue whether its the best one. I cannot say with accuracy whether it even measures properly. It has readings of 6% 7 8 9 10 11 12 14 18 22 25% on it. You stab in and turn on to the lowest reading. Keep turning until a red indicator light comes on. That indictes the moisture level of the wood.
Ive built a simple bookcase with dado sides that fit tight on assembly. The wood registered 8% on first check with the meter. I sabbed in all the pieces with that Timber Check. I felt safe with that reading and hoped those dados would remain tight as they will always be visible. I live on the east coast where RH is generally high. The bookcase went in a room that is never over-heated but the wood shrank leaving a slight gap on the top side of some of those fits. Oh well. I expected expansion. Wood and gaps, got to live with them but was that moisture reading accurate. I don't know. Any thoughts.
Jerome
Edited 4/15/2006 6:53 am ET by Jerome
Edited 4/15/2006 11:50 am ET by Jerome
I have a Lignomat that has 4 different settings depending on the 4 sub
species groups. There is also a compensation chart for temperture...testing at 80 degrees gives a different reading than 40 degrees. The newer more expensive digital meters automatically compensate for temperature.It cost a few times more than yours did so I would expect more accuracy. Lignomat is willing to do tests on other woods than they have listed which is a good thing for us. We do a lot of antique lumber that doesn't apply to their charts. Antique hear pine is difficult to measure as is pickle vat oak which has a lot of minerals from the pickle juices over many years soaking into the wood so we can't even use a moisture meter for that stuff. We use a lab oven to dry samples and do a weight comparison test from a test piece. Very slow but extremely accurate. For meters the point is to make sure all the boards you glue together are at the same reading.
Edited 4/15/2006 4:30 pm ET by RickL
