Hello all,
I am have built a 27′ long by 7′ tall cherry cabinet wall system. It is built like kitchen cabinets so it can be reconfigured. Being half of the upper cabinets are open shelf I want to find a way other then the standard screw through the face edge. I thought about dowelling between the cabinets, but then every one would have to be perfect to the others. there are 10 upper cabs. Any ideas? I think I will need 3 mounting per side to get the face somewhat smooth to each other.
"Knock-down" hardware
For connecting the components together, you might consider "knock-down" hardware designed for this purpose. Connector bolts and cap nuts might be what you are looking for.
http://woodworking.rockler.com/search?p=R&srid=S3-USCDR01&lbc=rockler&w=*&url=%2fproduct.cfm%3fpage%3d368%26site%3dROCKLER&rk=1&uid=940624269&sid=2&ts=custom&rsc=MGuHQLotY6nz0g8Q&method=and&stateid=s3C13B23C12UECMaF9&isort=globalpop&view=grid&sli_sid=v9100&newurl=http://www.rockler.com%2fproduct.cfm%3fpage%3d368%26site%3dROCKLER%26sli_sid%3dv9100
http://woodworking.rockler.com/search?p=R&srid=S3-USCDR01&lbc=rockler&w=*&url=%2fproduct.cfm%3fpage%3d369%26site%3dROCKLER&rk=8&uid=940624269&sid=2&ts=custom&rsc=682nHyUYhbgnpxb8&method=and&stateid=s3C13B23C12UECMaF9&isort=globalpop&view=grid&sli_sid=v9100&newurl=http://www.rockler.com%2fproduct.cfm%3fpage%3d369%26site%3dROCKLER%26sli_sid%3dv9100
Mounting
Trim head screws positioned so the side edge of the shelf hides it.
SA
