Move Tool Copying and Orbiting Inside a Stile
I have a slow internet connection where I live, and I wonder if that is the reason why Move/Control does not copy on my Sketch Up and why my orbit key will not go inside a rail to draw a rectangle and Push Pull a Mortise inside a stile. I read an old post in Design, Click, Build by Dave Richards about how you can use X-ray to make the mortise and that is what I did. I worked around the Move/Control copy function lapse by drawing lots of guidelines before making a rectangle and making the tenon. These work arounds are much more cumbersome but can work around the problems.
Generally all the answers to your all your issues can be found simply and easily by doing a quick search (clear and concise) via Google. There are hundreds of highly skilled Sketchup users that can provide help almost instantly. Many with video tutorials. To put even a finer point on it - you can use Sketchup's own forum. On the forum as well, there will be hundreds if not thousands of Sketchup users who will be willing to help you with any issues you may have now or in the future. All free of charge. I would suggest you consider availing yourself of the latter. https://forums.sketchup.com/
Thanks, user-7627473, I saved the forum as a favorite and quickly found others with the same problem and read the posts. I'm stubborn, so I'll keep at until I work out all of my (crazy pants) user bugs (:.
Thanks again, user 7627473, I got help from DaveR on the SketchUp forum and worked away until I got blurry eyed :).
