Hi all. Just joined the forum. After years of woodworking I’ve decided to make a grandfather clock. I am working on finials now but everything I read tells me I should have the movement and associated parts on hand before starting the clock case. I have reviewed some suppliers websites and there seems to be a wide range of prices for these items. I deal with Woodcraft frequently and they have a movement that seems quite reasonable when compared with others. As I have no experience beyond quartz movements I badly need some good advice as to what movement to buy. Any help on this will be greatly appreciated. – Thanks
Alan,
Look up a Company named S. LaRose.
Good Luck
SA
also look up klockkit they have some really nice stuff and movements in all price ranges if your going through the work of building the clock I wouldnt skimp on the movement , I think EMPORER clock co is still in buisness as well I built a clock with their movement 30years ago and its still running
I intend to build some clocks myself and have found these sites to be useful.
http://www.slarose.com/store/featuredproducts.ihtml
http://www.colonialtimes.com/
http://www.klockit.com/
http://www.murrayclock.com/
If nothing else at least you'll get some comparisons.
Ken
Sparrow hawk has supplied a good list of links. Just watch the guarantees; you'll find different time periods for the same product depending on who sells it.
I would stay away form the low priced mechanical movements. Sometimes you'll get one that lasts, but more often than not, they're only good for a year or less. If budget is a concern, stay with quartz.
In the mid-priced range, Hermele (that's what Woodcraft sells.) makes a good product. Keininger is higher in price, but is probably the best movement you'll find without moving up to a custom made model.
The type movement you want depends on the type of clock you plane to build. I only have experience with period clocks ( federal). For me the Kieninger movements are a good buy at less than $400.These are good quality German movements that will run accurately straight out of the box. I purchased mine from Merritts Antiques ( http://www.merritts.com). They also sell a true reproduction of a period movement, for over twice the price of the Kieninger, but these require a working knowledge of clock movements, since they need to be “tinkered” with to run correctly. While cheaper movements exist, the labor expended on a top quality clock is wasted without a corresponding movement and dial ( I have mine hand painted). All told, there will easily be $1000.00 in materials for a good tall case clock reproduction, and usually much more.
It is absolutely essential that you have your movement on hand. The process of mating a movement to a case is a fairly exacting and complicated task. I suggest that you prepare full size drawings, showing both a horizontal and vertical cross section of the hood and waist. Pay particular attention to the swing of the pendulum, to insure your waist is large enough to accommodate its movement. Also, a story stick helps to get the overall heights of the various components set ( moldings, seat boards, and hood dimensions etc.)
Few woodworking projects equal a well done clock, good luck with yours.
Rob Millard
Google for "black forest Imports." Deal with the California office.
WilliamI make something, sometimes twice, each year.
Thanks to all for some good information. The clock I am starting to build is a Newport-Style Tall Clock. Its the clock featured in an article by Robert Effinger in the Nov./Dec. 1985 issue of Fine Woodworking (No. 55).
