what is the best way to move a band saw from a shop where it was purchased to my shop. The drive is about 40 minutes and I drive a pickup truck. I am not sure weather to lay it down in the bed of the truck or to disassemble it partly or to strap it down standing up?
Depends on the saw. Old delta style cast iron saws have quite a bit of flex in the spine compared to the newer euro style steel saws. If it is the older type and you can unbolt the top assembly (like to add a riser block) then take it off for transport. My Laguna shipped to me bolted upright to a pallet so I would move a steel-spine saw that way even if it meant hiring a lift gate truck.
Moved a lot of machines and unless you are going to beat the crap out of it on the way home just stand it up and strap it down. Straps around the frame, not the table. Makes sure the straps hold it secure so it can't slide or tilt.
Oh, If the motor is mounted so that is loose and can bounce, I would secure it or take it off.
Last one I moved was a 30" cast iron machine. Same advice applies to moving a small machine as a large.
Not a band saw but we moved an air compressor about 10 miles in my truck. Top heavy. We pushed back in the bed to the cab, tied the bottom to anchors in the truck so it would not slide around, then opened up both doors and ran another rope through them and tied this down to prevent the compressor from tipping forward. No issues.
Depends on the saw size and type for me. 18" and above I would consider laying down on its spine as some can be top heavy. Less wind resistance as well. A 14" would be fine standing up.
Congratulations. You are now the proud owner of a Saturn V rocket.
Used with care, this will give you years of trouble-free band saw transport.
Please remember only to fuel with RP1, LH2 and LOX from approved suppliers, and to follow these directions exactly.
Band Saws have several components which may break loose during launch, so to prevent this, always remove the blade before transportation.
Ensure that your blade guide is fully retracted into the upper housing to reduce vibration and that all fixings are tight, to prevent loss and possible vaporisation by rocket exhaust.
Empty all storage areas as launch thrust can cause objects to move in mysterious ways. Ensure all doors are held firmly closed with plenty of blue tape. DO NOT USE GREEN TAPE - it will clash with the rocket colour scheme.
Motor mounts can be fragile so it is best to mount the motor away from the load bearing surface. Removing the motor is not required.
Placing a few layers of blanket or bubble wrap under the saw will prevent scratching the snazzy NASA paint job and of course your saw.
We recommend genuine JPL brand ratchet tie-downs to hold your saw down to the load bed. It is wise to use at least three of these to prevent flexing during flight and to use padding as no-one likes chafing.
Band Saws are heavy. To prevent personal injury, ensure that there are at least 2 people helping you, or use mechanical lifting aids.
Saturn V rockets are also a bit heavy. You may need to reinforce your launch vehicle. If uncertain of safety protocols please consult a qualified rocket engineer.
Or you could do the same thing in the back of a ute/pickup, van or hire professional movers. That will work too.
The Saturn V is a great idea if you're setting up your shop on the moon.
Your fuel choices are good but don't forget to fill up the tanks. The F-1 engines burn about 15 tons of fuel a second.
What's that in MPG?
I picked up an old Rockwell 14" bandsaw and lifted it by holding onto the table. Later I found out this is a no no and can break the trunnions but it survived. I left the motor on and laid it down also not good as I read here. The saw is working fine so maybe I was just lucky. If transporting upright strap the piss out of it and recheck several times. May even want to bolt it to a wider base too. That is a lot of mass located high above a narrow base. Be careful and good luck!
I had hope to get my grandpa's old delta but when he and my uncle moved it, well let just say god love 'em. Watch out for the cast neck.
My truck has a cap, so standing anything up has never worked for me. And the big tools go down cellar stairs, which is not easy.
If it was a Delta clone, I would take off the top assembly and the table. Then move the three parts. I wouldn't have any qualms about laying those parts down.
I bought a used Grizzly 17" model. I took my pickup and a friend to load it up and bring it home. All I did was to bring a piece of plywood to lay th saw down on and for ease in moving it around. Also some straps to keep it from shifting. the move went great.
Moved a 1890 cast iron 36 inch band saw from toronto to Victoria BC by bolting it to a heavy pallet and loading it to a overheight trailer with a fork lift.The saw was 8 ft tall and just slipped in the truck with one inch to spare.I originally picked it up ate the xerox labs in Toronto by laying it on its cast iron back.I converted it from belt drive to motor and you could stand a nickel on the table when running and it would not fall down
