Anybody use two of these Shop Fox veneer clamps to make a Moxon vise? Looks like a slam dunk to me but I may be missing something….
Those are designed to press, but if you ditched the end pads and buried the threaded ring portion in the body of your moxxon it could work. I used something like that to build a wagon vise into my bench and it works very well.
I think you will find an uncomfortable amount of thread protruding unless you intent to significantly modify its operation.
exactly what i used to build mine 4 years ago. Parts were the right price and does everything i expected a moxxon vice is meant to do.
ray
I considered those when I build mine b/c I wanted it to screw in, not turn on the threads like most Moxons.
What MJ said is what I was going to do, and put a bushing between the handle and chop to offset.
I ended up going with threaded rod and wheels, locking the wheels onto the threads and burying a nut in the rear face.
The link below is an article by Jeff Miller that has a bench top bench with a Moxon vise made with veneer clamps: https://www.finewoodworking.com/issue/2005/03/issue-176
I made a similar one but used the parts from an old cheap wagner bench clone.
I did one using Golds Gym dumbbells. I think they are around $7. You can thread them in and and out so you don't have more bar out front than you need. It was what I wanted at the time, cheap.
I did plans for a fellow for a simple portable Moxon-style vise using the Gold's Gym dumbbell handle for the screw. It clamps to the bench. This is a view from the back.
Thanks to all. The link to the build in FW looks perfect...
