Darrell,
I am designing a mission style mule chest of drawers (two chests, side by side, with a center divider in common, approximate dimensions 65”Wx18”Dx46H). I am planning to make a case (3/4” solid quarter sawn white oak panels), dovetailed at the top corners and a center divider (either solid or framed?) attached to the top with a sliding dovetail, and continuing to floor. Each horizontal and vertical drawer divider will also be attached with a sliding dovetail. The base of the case will consist of the bottom 3” of the sides and two front and back pieces attached with a through wedged tenon to each side. Each piece will have a curve removed from its center creating a foot at each corner and the center of the front and back of the case.
My concern is the joinery of these front and rear pieces to the center divider and the overall strength at the center of the cabinet.
I would appreciate any insight you might have.
Thank you,
Michael
Hi Michael,
I am not able to visualize your design at the base - would it be possible for you to post a drawing ?
thanks,
Darrell
Darrell,
The base of the chest is similar to the one in this link.
http://www.restorationhardware.com/rh/catalog/product/product_detail.jsp?productId=prod1045015&navCount=2
My question is concerning the joinery of the bottom front pieces to the center divider.
As I mentioned before, the sides will be solid and the bottom front pieces will attach to the sides with through tenons.
Please let me know if you still need additional information.
I appreciate your help,
Michael
Hi Michael,<!----><!----><!---->
Thank You. I believe I have a better understanding of your question now. <!----><!---->
My concern with the design would be the center divider. The ¾” thickness may not be enough thickness to support sliding dovetails coming in from both sides. If possible I would increase the divider thickness to 1” and even 1 1/8” if possible , while at the same time making the sliding dovetail as shallow as possible – maybe 5/16” or so. <!----><!---->
I would also keep in mind the fact that the solid components will move much more than the framed components. (i.e.: a framed divider would not move at the same rate as the solid top and bottom it is attached to)<!----><!---->
As for the skirts (curved rail at bottom of case): they are not contributing greatly to the cabinet’s strength. The strength should be coming from joining the sides- top - bottom - and the back. If you increase the thickness of the divider you should have enough material for adequate shallow mortises coming from both sides. If the divider is ¾” thick I would recommend offsetting the joinery to the skirt.<!----><!---->
Darrell<!----><!---->
