I’m just finishing up a small jewelry box, where I put shellac on and am applying a final layer of wax with steel wool. This may be a stupid question, but is there any benefit to put on a second coat of wax?
No, the solvents in the wax will dissolve the underlying wax. You then end up with a gummy surface that does not buff well.
Despite the TV ads for Pledge I don't think you get layers of "waxy buildup" as the solvents in the paste wax just melt the old wax. I am sure you will get some additional feedback on this question. Take a look at some of the backissues of Fine woodworking as they have had some articles on wax.
Good luck
Troy
Wax sticks to almost everything except itself. When you buff it all the wax is removed except for a microscopically thin coat. The only benefit to a second coat is catching areas you may have missed with the first coat.
My experience is not as stated by others. Liberon, maker one of the best paste waxes, recommends multiple coats for new applications or very dry wood. I suggest that you apply a single coat, let it dry and buff it out followed by a second coat on half of the box and see the difference for yourself: it is noticeable both by eye and feel.
What you say is true if you are applying wax to a virgin wood surface. The solvents are drawn into the wood and the wax solids fill the pores. It takes a number of applications to fully fill the pores.
However, the original question was about applying wax to a shellac sealed surface. A finish sealed surface will not act like a virgin wood. The wax stays on the surface and subsequent coats dissolve the prior coats. Wax works best when applied and buffed in a very thin coat.Howie.........
Thanks - I understand the difference in the application on raw/virgin wood and I also know that there is a noticeable difference between a one and a two coats appliation on a newly finished piece. It is easy to test.
Maybe its the extra elbow grease :) Troy
Naw, I use a rotary buffer :-)
