Hi Everyone and Happy New Year-
I have been asked to make a buffett very similar to the one I have attached. My question is-does anyone have any suggestions for router bit sets that would allow me to make the muntins/mullions in the glass doors? Although I have made large single pane glass cabinet doors before, thiswill be my first attempt at making the multi-paned style shown. Also, what are peoples thoughts on making it a single large pane with “false” muntin/mullion dividers? Oh, and can you tell that I am not sure if they are called muntins or mullions? Thanks to all for suggestions.
Cheers,
Kraig
Craig,
In a framed door, the vertical internal frame divisions are called muntins, in a window they're called mullions. There's very little difference except for the fact that one is rebated to receive a piece of wood and the other rebated to receive a piece of glass.
Cheers,
eddie
Eddie, and Kraig,
Interesting, in the shop where I learned sash making, the longer bars were the muntins, in the (cupboard, not house) doors we made, they ran side to side. What they called mullions were the shortest bars, that ran between the muntins, vertically.
However, I've noticed that in the old windows in my c.1850 home, the longest sashbars run from top to bottom. My dictionary says mullion is from the Old French for median, the picture shows the example in a vertical orientation; muntin, I've been told, derives from the French "muntire", to rise up, and I've been told that the vertical bars are muntins, whatever their length.
I'm guessing that at one time, tradition dictated that the longest bars "rise" from the bottom of the sash frame to the top, and those were muntins. When the orientation of the muntins changes to horizontal, the terminology gets confused. Further muddying the waters is the practice as you noted of calling the internal framing in a door a muntin if it's vertical- I guess the horizontal framing member is still called a rail. In one shop where I worked, the short vertical member that separated the loper (pullout lid support) from the top drawer in a slant front desk, was called ...a mullion!
Cheers,
Ray Pine
Hi Ray,
A drawer muntin is also the central support in a wide (>600mm) drawer that prevents the drawer bottom from sagging.
Cheers,
eddie
Edited 1/25/2006 3:32 pm by eddiefromAustralia
Hi Everyone-
Thanks a million (or is that a muntin or a mullion?) for all the great information. I had thought about using the same bit set that I use to make the stiles and rails but had not gotten around to experimenting yet. Thanks for confirming my suspicion Mcain. But also, like usual, if there is a specific need there is almost always someone who has met it in some way. Thanks to CharlesM and Freud I will be most likely go that route. Also thanks Eddie and Ray Pine for the background info on the proper terminology. Learning the language of woodworking is almost as much fun as making sawdust.
Well, with any luck I'll get the project knocked out here before too long and maybe, just maybe, it will give me reason to stop thinking about posting in the gallery and actually doing it.
Thanks again-
Cheers,
Kraig
You can use the same rail and stile (or cope and stick) bits that you use for a raised panel door.
The Freud 99-270 is specifically for this type door:
http://www.freudtools.com/woodworkers/rep/router_bits/Router_Bits/Cabinet_Door/html/Cabinet_Door_1.html
Freud America, Inc.
