Previous owners left this hanging in the basement. Can you tell me what it is? It’s about 6 inches long.
Janet
Janet
I am not sure what it fits, but it is a combination box-end and spanner wrench. The box-end part is easy, the spanner end fits in a pair of slots in a cap or retainer, typically one that has a hub or axle protruding from the center. Typically this type wrench would have been supplied with a particular machine to make adjustment or repair simplier. Not many of us have an assortment of spanner wrenches laying around.
Bruce
I just bought an adjustable spanner wrench from Garret Wade. I found I was short the proper sized spanner when I needed a custom collar to attach a disc to my Bosch angle grinder.Frosty“If you put the federal government in charge of the Sahara Desert,
in 5 years there’d be a shortage of sand.” Milton Friedman
Any old furnaces or boilers in that basement? Wouldn't be surprised if it loosened a fitting thereon.
It looks like the type of wrench made for water filters, oil filters, and water softeners. Is there a manufacturer's name on it?
Shop Manager for FWW Magazine, 1998 to 2007
Champion Brass
Los Angeles CalifThere's a price sticker on it that says Lumber City.
A google search reveals that Champion Brass makes sprinkler systems. It is probably the tool used to remove and install sprinkler heads.John White
I am impressed! Thank you.Janet
You are welcome, this is what a tool geek does for fun.
John White
That's it, John. I have one just like it - although I haven't used Champion sprinkler heads for several years.
This tool is commonly held by the short end with the wider u placed around the neck of young children. Works well for keeping toddlers at a distance while spending hours surfing message boards.
I think it's a modern day boot jack.
Tool for brass sprinkler heads. Hex end tightens/loosens spray nozzles; spanner end fits into two notches to tighten/loosen the whole head from the riser.
Makes sense. It was hanging on the end of the workbench closest to the water shutoff valves. Thanks!Janet
