WHAT’S THE BEST WAY TO FILL GUN NAIL HOLES? WHEN I DO TRIM WORK (FRAME & PANEL PANELING, CROWN, ETC.) I FINISH THE WOOD WITH WATERBASED FINISH B4 INSTALLING & THEN USE A WATERBASED COLORED PUTTY TO FILL HOLES BUT GET A RESIDUE AROUND THE HOLE FROM PRESSING IN THE PUTTY THAT WON’T COME OFF. THE RESIDUE IS BARELY VISIBLE BUT I WOULD LIKE TO ELIMINATE IT. & WHAT TO USE TO APPLY PUTTY, I’VE BEEN USING A NARROW PIECE OF PLASTIC PUTTY KNIFE, CUT NARROW THE SIZE OF THE HOLES. THANX.
Colored wax fillers work well for small holes on finished wood.
Glendo.
Jim,
I use Blendfil sticks on wood that's already had the finish applied. They're round, paper-wrapped, crayon-like sticks in various shades to match the finish. Availible in paint dept of most home supply stores. When I have a bunch of holes to fill I chuck one in a cordless drill and spin it into the holes. They leave an excess of filler around the hole which is buffed off with a paper towel. GP
Not using nails completely avoids this problem.
If the wood is exposed to the eye, I usually put a dab of glue in the hole and put some of the dust (from the same wood) on top of the glue. I rub the mix into the nail hole and immediately sand over the area. Makes the nail hole practically disappear.
Len (Len's Custom Woodworking)
I use some blendfil sticks that others use, flick your bic, just heat it a little.
listening for the secret.......searching for the sound...
