Name of a certain technique–concentric circle sawing with a slight bevel
I know of a certain technique to save expensive wood when turning for a bowl or dish.
It is to use a scroll saw or jig saw to cut concentric circles at a slight bevel to create a blank before turning. The angle of the bevel and the kerf width of the blade will decide how steep or shallow the blank will be.
What is this procedure called? I want to search for video on insight into this. What is the best way to hide the drill holes etc.
Thank You
Stacked ring lamination.
Thank You.
I found the following :
https://www.youtube.com/watch?v=LB3-sEx3ruE
Actually what you cited is something new and possibly useful to me.
What I had originally in mind is something similar but not the same. If you cut with a small bevel, say 5 degrees, and if the wood is thick enough and the kerf of the blade is narrow enough ( a combination of bevel angle, wood thickness, and blade kerf), there will be a slip and the smaller ring will not drop. The gluing surfaces will be the sides of the rings, not their tops.
Again you post a question and then pontificate. I'm out.
I thank you for pointing out stack ring lamination, but I was merely pointing out a somewhat different approach as exchange of ideas and knowledge.
I see nothing wrong.
I've heard it called an "economy bowl"
I found out it is also known as insular ring side lamination.
