I am interested in purchasing either a 1000 grit Norton waterstone or the new 220/1000 grit combination Norton waterstone. Is a 220 grit stone useful? If so, for what, and is it necessary or advisable to get two separate stones representing 220 grit and 1000 grit respectfully? I already own a 4000/8000 grit Norton combination waterstone and an 800/4000 King waterstone.
– Peter
I have the Norton 220 1000 4000 and 8000. I never use my 220, If I needed to go that coarse I would use sandpaper. Since you already have a 800 stone why even bother with the 1000?
I want the 1000 because I think Norton stones are much better than King stones and because I wanted to lessen the jump to the 4000 stone. What's your opinion of combination stones?
I have the norton 1000/8000 stone, and a King 1000/4000 stone. I went with combo stones because I'm a little cheap when it comes to buying stones, and because I do a lot of prep sharpening on sandpaper/granite and a ceramic stone for my gouges.
If I were to rely on waterstones only, I'd NOT get combination stones. I read an article, and watched a Rob Cosman demo, where you use your stones as a team. Use one face to sharpen, the other face to flatten the next finer stone, continuously like a system. It was a lot faster and cleaner than the way I use my diamond stone every once in a while and make a huge mess.
My tools are stupid-sharp. They way I work suits me on the whole, but I believe there are better ways. I really do like the feel of the Nortons over the Kings.
Just my opinion of course....The older I get, the better I was....
Hi Peter. I agree that Nortons are better than Kings. I used to own Kings but I bought the Nortons after trying them. I have no idea if the difference between the 800 and 1000 is as close as the grit level would indicate, so just going by the numbers I would not spend the money on a 1000 unless I had tried one or the money was burning a hole in my pocket. On the subject of combination stones, I think there is hopefully nothing wrong with the Nortons. My first stone was a combo King stone. When 1 side became noticeably thinner than the other side the stone started to warp. I flattened it 3 times I think before it was useless. For this reason I would not buy a combo stone again. Other than that I think they are fine. As another poster said, I too use the Cosman method of sharpening. I have 2 1000 grit stones that flatten each other, 1 of the 1000 stones flattens the 4000 and also the 8000. I have been doing it this way for several years and I do not believe cross contamination to be an issue. Peter
