Hi:
Does anyone know what cutterhead speed manufactures recommend for joiners? I assume that would be in revolutions per minute. Any help would be appreciated
Thanks in advance,
Dennis
Hi:
Thanks in advance,
Dennis
Post your make and model number and I'll see if I can help.
Samuel P. Huntington
You can go to many manufacturers, dealers websites and get the specs on many different machines and answer your own questions. Beats waiting for an answer!
Sorry if I didn't post enough information. The Joiner has no brand name, it's just labeled 4" precision jointer. It appears to have been made in the 60's and really is a quality product ( except when it comes to changing blades -- The new machines are so much better). The pulleys are currectly set up to produce 4000 rpm cutterhead speed and I'm wondering if thats not a bit slow.
Any information would be appreciated
Dennis
4,000 to 4,500 RPM is typical for a 4" jointer so the machine is set up correctly. Unless you are comparing it to one of the larger jointers with a spiral or disposable blade cutter head, the method of mounting the blades on your machine hasn't changed from the typical machine being sold today.
Thank you John, I appreciate the information.
Good luck and be safe.
Dennis
Dennis, my first jointer was a Rockwell 4".4000 rpm's sounds correct to me. It came with a 1/2 hp motor that was plenty hefty for a small jointer.
mike
Mike,
Thank you for the confirmation -- much apreciated
Dennis
