need advice on hand narrow belt sanders
Hi All, We’re carving free form bowls and I’ve been looking at the Makita 9031- 1 1/8 x 21 belt sander. I’m hoping that this is a tool that could be used to clean up the interiors, but I’m concerned that the belt won’t track if I am using this primarily on the roller tip? these cost about 220.00 and it looks like the only other alternative is the dynabrade air models that get spendy fast, ( 600-1000.00) but are designed to be run on the tips just fine. I’d like to not have to spend that much but don’t want to buy a lesser tool that won’t do the job.
Does any one have experience with the makita?
Thanks in advance for any help!
Aloha, Tai
I have a dynabrade and it is worth every penny. Mine is the electric model and it works fine. I'd prefer an air tool, but I like to use it off site where a big air compressor simply isn't available.
Thanks..... down deep I know that you get what you pay for, and the other dynabrade stuff I have is really great . ( but I bought it used and avoided the initial "ouch") You must have the Dynafile ll ? I would be looking at the Dynafile lll to get the wider belt possibility.
And thanks for the thought Steinmetz, but the only thing that would happen if we stuck these things on a faceplate is that we would get very nervous and then get to watch a great disaster if we actually hit the switch....
Onward!
Tai
HITAI, I used my Makita to chamfer plate glass, and to round over the corners. I don't think it would do a smooth job on your bowls. HOWEVER, If you can center and mount the bowls on a faceplate or some kind or motorized spindle, you might try a boring bar sander. http://www.packardwoodworks.com It is a hand held device which will sand the insides and outsides of revolving bowls due to its swiveling and revolving rubber pad It uses Velcro sanding discs.
Other manufacturers have a ball shaped pad as well.
Off hand, I can only remember the packard tool, although if you check out wood turning sites, you'll find what you want. Stein.
Edited 12/4/2003 7:27:37 PM ET by steinmetz
Edited 12/4/2003 7:40:44 PM ET by steinmetz
