We will be getting a table saw blade guard soon. One with a dust pick up port. Our plan is to hook a shop vac up to the port on the shroud covering the blade.
I know there are several devices out there that will automatically turn on a vacuum when the tool is turned on.
But I’m not sure to approach this with or 5hp, 3ph Sawstop. The saw is hard wired to a cutoff box and I haven’t seen any of those sensing gizmos for 3 ph equipment.
Here's one that might work for you.
http://www.ecogate.com/home-comercial/home-comercial.htm
I was married by a judge - I should have asked for a jury.
George Burns
Already have one of those hooked up to dust collector. What I want to do is hook up separate vac to Biesemeyer dust shroud on blade guard.
Edited 10/22/2009 8:22 pm ET by ted
Wow, that looks like the ultimate control. I'll have to remember that when I set up dust collecting. Hope it isn't too expensive.
I looked at it once, but did not have the money. If memory serves right, the base system for the home shop was not that bad. great looking stuff. I was married by a judge - I should have asked for a jury.George Burns
You could use a control relay or small starter to energize the dust collector. The control device would be sized for the HP of the dust collector. You would need to match the relay/starter coil voltage to the 3 PH line to line voltage, (probably OK if it is 277 V). Or you can put in a small transformer to get 120 V for control. Of course, you'll need a "power" circuit for the collector. You'll need to size the wires and fuses per the National Electric Code.
When you close the manual switch to start the saw the controller picks up and starts the collector. When you open the saw switch the collector stops.
You'll probably need an electricain that is familiar with industrial control and the NEC. But I'll bet he'd be cheaper than the above mentioned system.
