Hello,
I am attempting to make my own interior trim for my house. Does anyone have any good “recipes” or designs that they using using standard router bits and table. I want to make wider type of trim with a substantial look to it but nothing super fancy.
Any help or methods and resources would be much appreciated.
Ralph
Hi Ralph,
I once made what I call stepped crown molding out of 3/4" pine. I first sketched a profile that I wanted - using what I had for router bits at the time. Of course this also provides you with an excuse to buy more bits too! :-)
I ripped one board into 3 different widths, i.e. 3", 2" & 1" (not exact widths).
Using a router table with a roundover bit I ran it through on both sides of one edge to make a bullnose profile; ran the 2" piece through using a cove bit and put an ogee profile on the 1" piece. When stacked together it created fairly reasonable looking crown molding.
This worked well as I was able to screw the top 2 layers in and then countersunk finish nails for the bottom (ogee) profile to cover up the screws.
Not wishing to rain on your parade but unless the trim is very simple it and you only need a small amount,it may be cheaper and faster to concoct your own style out of a combination of readily available mouldings.Handling long lengths on a router table and maintaining consistancy is quite an undertaking.We make a lot of Victorian custom trim using 3 shapers and power feeds even that is a pill compared to running it on a sticker with multiple heads.
Well, there's "trim", and then there's "trim". What style? Victorian, Modern, Ranch, A&C?
As another poster pointed out, making complex mouldings with a router can be tough, since a router in a table will work best on, or close to, the edge of the stick. You can at least partially overcome this by using multi-part designs. If you do that, you could combine wide stock you make up with, say, a coved rabbet on one edge, and add a more complex stock (i.e., purchased) piece for the final section. (Like the 3-piece base found in some of the old Victorian-era homes.)
Another option is to use a moulding head on a TS. This would let you deal with wider profiles.
Google "moulding profiles" for a plethora of ideas.
Mike Hennessy
Pittsburgh, PA
PS: You might wanna post this Q over at breaktime for some additional insight from the trim carpenters who hang out over there.
Edited 2/23/2009 7:43 am ET by MikeHennessy
Thanks for the advice. I see that I am going to have to do some additional research. I always see these profile bits advertised bud didn't know if the are worth the cost etc.
I am going to have to look more into this.Ralph
I'm with Jako and Mike on this one. I have made about 700ft of cherry trim (thus far) for my home with a shaper and power feeder. I would say thats the min. for such a task. Another thing, if you are thinking about staining get ready for a bit of hand sanding. Been there, done that. In my case I am using Cherry and in the arts and crafts style so I would have went into the poor house if I had bought it from a moulder co. At the end of the project I do have some really nice machines, but it is far more time than I expected.
Brad
Thanks for the advice.Does anyone own a planer/moulder? What are the capabilities of these machines and do they work anything like they advertise etc?Just trying to gather some knowledge---
Lots of people use the woodmaster, Logosol and the W&H. Keep in mind the shaping is only part of the battle. Unless you can find blanks (rough shaped timbers) in the size you need, a lot of the work is getting 4/4 stock sized.
You might want to take a look on the Woodweb or the Sawmill creek site for some more info too.
Brad
