I’m building some guitar stands and am thinking of supporting the body and neck with 3/4″ dowels covered with foam tubing to protect the instruments. The stuff to insulate pipes is split and too thick. Anyone know of any easy sources?
Norse
Norse,
Instead of foam tubing, I'd recommend using general purpose PVC tubing. It's very durable and is non-marking, plus it give the guitar a little traction when on the stand (i.e. the instrument won't slide around). PVC tubing is very inexpensive and can be found in the plumbing department of any home center. You'll have a choice of clear, black, white, and clear with braiding. Heavy gauge surgical tubing is another option.
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
I don't think foam is advisable -- somehow I get the jitters when I think about a beautifully lacquered guitar resting against that foam. I played (or tried to) guitar for several years and invested considerable $$ in a nice Guild. I seem to remember the stands having a rubber of some sort on the neck brace and bottom bracket.
forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
surgical tube..that,s what ya want
Yes! That's it!forestgirl Another proud member of the "I Rocked With ToolDoc Club" .... :>) you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thanks for the tips. I found some clear vinyl tubing at the home center which will work but I'll keep looking. The commercial metal guitar stands have a foam rubber covering that seems to work fine but my research so far all have large order requirements or they are made for a specific purpose and are very expensive. I'm not sure I'll make more than a few guitar stands but who knows.
Thanks again,
Norse
Can you get them as replacement parts from a store that carries that particular stand?
Yes, I tried that and even called the manufacturer who gave me a little song and dance about getting it from different suppliers (which could of course be very true, I was only asking for one!). I'm also trying to avoid buying a "minimum" order.
I was just out in the shop fussing with the prototype and am starting to think about using square pegs mortised into the uprights and a felt covering. (This was before I saw the post from Ben, like minds.....) There is very little weight involved and I'm pretty careful about how I set the instrument in the stand.
Norse
Edited 1/20/2004 12:58:13 PM ET by Norse
Why not use the material that guitar cases are lined with? (felt, velvet?)
There's liquid sold for covering tool handles. One brand is called "Dip-It", or the like. You dip the handles of your pliers or whatever in it, and hang it up to cure. It forms a rubbery thick conformal coat on the handles. I think it is available in black or in red.
