I just received my new bandsaw blades from Suffolk Machinery. (Thank you FG & the rest!) All is well. There was a moment when attempting to coil the old blade that briefly turned into “Charlie Brown and the kite string”, but I managed to get the *&%$ thing off of me with just a few scratches. I decided that it could hang just fine uncoiled. Any-who….. the new blades seem cool, I tensioned the new one as suggested seemed pretty good. I still have the “nod” thing going on, but other than that all seems well.
Thanks Again for the suggestions,
John
I hang mine uncoiled as well, small ones aren't so bad but coiling,uncoiling a 1 1/4" 1.3 tpi is like wrestling with a shark
I've actually done that and I would take the shark over the bandsaw blade, at least when you tell people how you got hurt, it makes for a good story. The bandsaw blade story gets them backing away! But thanks! I DO appreciate it.John
I'd like to watch Norm uncoil one of those 3" babies for his Hitachi resaw. I'd either learn something or it would be really entertaining!
See the link below for an easy way to coil bandsaw blades, including a short video showing how to do it.
I fought them myself for a long time until one of my advisors took pity on me and showed me how to do it without turning the day into a self-sacrifice of sorts.
http://www.newwoodworker.com/coilbsblde.html
Tom Hintz
Because there is always more to learn!
That looks WAY too easy! Either it will work like a charm or I'll decapitate myself. If I don't write back, you'll know what happened!John
Thanks, Tom, I'll save that link for others. FWW used to have a video in the archives, but they pulled it before the changeover. Really irritating!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Suffolk Machinery....great Call. i just got done goofing around with some Brazilian Cherry and WHAT A DIFFERENCE!!! Thanks, (Again)John
Ain't it wonderful?! Glad you a happy WWer.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
WOW! Something that works as advertised! No problem, got it on the first try! Thanks!John
Tom,
Cool link. IT really works! Thanks!
Roy
Tom,That is a great tip! One of the world's mysteries is solved!Thanks,Bob
What do you mean by the "nod" thing going on? I must have missed the earlier post/thread.
Roy
Dear Roy,
Against my better judgment, I bought a "Ridgid" 14" bandsaw from the "Borg" It is basically the 14" Delta with 3/4 hp motor. It seems to cut fine, but there is a "vibration"(?), it's sort of hard to describe, not really a vibration, but the saw seems to "nod" a bit while running. Call it a vertical flex. (?) Almost what I would expect from an out of round wheel. Although I am an experienced contractor, I am not an experienced bandsaw user. I don't think this is normal, but I am chalking up to a "cheap" (er) tool, coupled withe fact that I am the first person to caution others about tool purchases from HD, so it my own fault. I have eyeballed the wheels and they seem to run true, if they are out, I can't see it, and I would think that it would be pretty noticeable, given the amount of "nod". It doesn't render the saw unusable, by any means, but I can see and feel the "nod". I thought that the belt was too loose or tight, but that seems fine, I have tried a new blade with the same results. John
That "nod" may be simple to fix, Just like a wobbly chair! Saw base may no be sitting exactly flat on the floor or mobile base. My Jet 14" "nodded", found that one corner of the base was about 1/16 off the floor. A shim fixed it up pronto. Intend to install adjustable rubber feet when I can get to it.Work Safe, Count to 10 when your done for the day !!
Bruce S.
Interesting, I will try that! May explain why it seems to be more pronounced at some times as it is on a mobile base and I don't always set it up in the same place. I'll get back to you.Thanks!John
