Hello All,
I am a new Knots participant although a finewoodworking.com enthusiast and beginning woodworker. I am about to start building what is for me a very big and ambitious project: a basic version of a Roubo workbench as discussed in Chris Schwarz’s recently published Workbench book. I have to make the length 6 feet rather than 8 feet and instead of 4 inches thick it will probably be 3 1/4 or 3 1/2 inches thick Southern yellow pine, 16 pieces laminated to achieve a top width of about 24 inches. The base and stretchers will be jointed 2×4 fir, 4 pieces laminated per leg. In this design the outside surfaces/faces of the legs are flush with the front and back edges of the top – there’s no front or back overhang.
Here’s my first design question:
– with these dimensions and materials, how long should the base be? For now I will have only one vise on it, not the leg vise that is part of Chris’ design but a Record quick release vise. Another thread I found on Knots suggests that the vises used will dictate the length of the base. If I do that then the ends of the top will extend past the legs about 1 foot and the base will be about 46-48 inches wide. Does that sound reasonable?
Thanks to you all for your help and advice. I suspect this will be the first of many questions as I go through this project.
Best to all,
Vivian
PS I do not know why “jbtx” is in the “From:” line – I don’t think I ever gave myself that handle. Anyone know how I can change that? Thanks!
i'm not experienced enough / qualified enough to answer you question directly, but I'm investigating building my first real workbench as well. I found another article from Chris Schwarz for a $175 bench (link below). I'm going to build the legs thicker (~3.5") out of FIR and bring them out flush w/ the top - roubo / Holtzapffel like). I may beef up the stretchers too. Other than that, I believe I'm going to copy the dimensions on this plan.
I hope this helps.
http://www.popularwoodworking.com/projectplans_display/?planid=11098
I don't know how to change the "jbtx." I tried changing my own handle, but couldn't figure out a way to do it. As far as I know, the only thing you can do is re-join with a different one.
I think you've got stuff figured out pretty well. As for the length of the base, the rule of thumb would be, "as long as it can be without interfering with the vises." So, a foot shorter on each end should be okay, unless you plan to someday install a long-throw tail vise. The Veritas twin-screw vise needs a little bit more than a foot, for example. Don't forget to take into account the thickness of any end caps in your calculations.
For what it's worth, I built a similar bench, with a top about 7' long. I have a 14" cantilever on one end to allow for the vise, and leaning hard on this end can raise the other. With a 6' bench that tendancy would be even greater. To do the math, a 3-1/4" thick x 24" wide top would need to be just over 7' long to remain stable with a 150 load on the end. The weight of the legs and tressels can alter this number a bit. This shows my bench to be borderline...maybe that's why an 8' bench of this style prevailed over the centuries. When I added a face vise at the opposite end of the bench (around 30 lbs) I could no longer lift the end in this manner. With a shorter bench, you may need to store materials on the tressels or otherwise add weight to your bench for stability.
Weight is definitely the key - the heavier the bench, the more stable.I like the Rubio design, but there are plenty of others out there to look at - search the bench design ideas out there before you lock into one...Tom Iovino
Tom's Workbench
http://tomsworkbench.com
A lot of people use sandbags, etc. for exactly that reason.
Thanks Steve, BWW, Tom, and tuolumne7 for the links and advice!
There are so many excellent designs out there it is difficult to settle on one. Chris Schwarz's discussion of the Roubo bench made it sound and look really appealing to me. So for better or worse a simplified version of this bench is my plan. I hadn't thought of the cantilever issue - that's an important point to consider. I'm going to take that into account and see if I can get the Record face vise to give up a few inches to the length of the base. Looks like I'll be jbtx for the immediate future.Thanks to all!
Vivian
jbtx,
Hey, it's easy to type too! I doubt that anyone will connect jbtx with Vivian. :-)
Anyway, I'm not all that familiar with the Roubo bench but I'm curious as to why no overhang on the bench? Most benches that I've seen have this as I suspect it affords better clamping capabilities. What are your thoughts with regard to no overhang?
Chris Schwarz is a big proponent of the no-front-overhang design. It allows you to easily clamp a panel to the front of the bench. Imagine holding a large panel against the front of the workbench. The leftmost part can be clamped in the front vise, and since the rest of the panel is lying flat against the front of the leg(s), you can clamp the rest of the panel to said leg(s).
Bob, I think the reason for Chris's no-overhang approach is the bench is really intended for hand-tool use. His approach is all about holding the work down so you can plane every edge and face of any size board or assembly, which means relying on bench dogs, hold-downs, planing stops, and vises. I could be mistaken, because Chris does use power tools too, but that's what I remember from his book. Norman
disclaimer: I'm a newbee too:My take on why no front / back overhang is good. I do believe there are hangovers on the right and left side of the roubo:1. allows you use the legs to do clamping
2. allows use of deadman easilyAlso, since i don't believe there are front/rear top rails, you can still use the top to clamp to.- Brad
Brad,
Man don't you just hate hangovers! Especially on Monday mornings. :-) That's another reason I stay away from roubos.................
