I want to restore a water-damaged mirror back sideboard. The original finish was destroyed, is now stripped, and the piece sanded. It is made of a variety of woods, including fir, birch, spalded maple, and red gum. I want to get it as uniform as possible, ending with a sprayed lacquer clear coat. Would I be better off starting with an NGR or an oil base stain? Thanks in advance for any help you can send my way. Rand
I would definately not use an oil stain--the woods you mention don't stain very well by themselves, and the oil stain would only accentuate the differences among them.
You might start with a sprayed dye such as the ngr to help establish a base color.
Then, for most of the coloration I suspect you would be best off spraying tinted lacquer, planning on multiple coats to creep to the desired intensity. If it is your intension to maintain some the the grain differences among the mish-mash of woods use largely tye toned lacquer (the perfect place for TransTint or similar concentrates), If you want to obscure most of those differences, then a pigmented toner would be the thing, giving you a finish verging on being a paint. .
Yes agree with steve.
Use dye stain, and spray to apply it.
By this you can easier in controll your color result.
I already posted some articles about how to make color in wood finishing, You can find it in my webblog.
- How to match color in wood finishing
- Stain in wood furniture finishing
- Color wheel for wood finishing
Good luck
