I’m a beginning woodworker. I’ve read in Niall Barrett’s book titled Bookcases (The Taunton Press, 1999) about a notched shelf support system for bookcases. I’m working on a tall bookcase, and I would like to use this zig-zag (sawtooth shaped) notched shelf support system for the adjustable shelves.
I’ve read elsewhere that this is an old and traditional way to support shelves that are not fixed.
Does anyone have any tips on how to cut these notched shelf supports? I would appreciate any help.
Sincerely,
Joe
Joe,
I have some of those kind of shelf supports in some antique furniture. I'm not sure if I would just have fun on the bandsaw using a miter or make a jig for the table saw. The TS option would be more exacting buthte BS would be more fun.
Joe,
I made some of these a few years ago after scratching my head about it for a while (I also have Barrett's book and was disappointed that with all the info there were no hints on making these supports)
I ended up using 1x stock 2-3"wide. I made a indexing jig for the table saw to space the vertical cuts and then marked and cut the angles free hand on the bandsaw- then ripped the four pieces I needed to 1/2" thick.- it gives four pieces that have the notches in the same position. Seemed to work ok and is a great look for early 1900's bookcases
Hope this helps-
Thanks for the suggestion. I don't have a bandsaw yet, so I'll probably cut these notched shelf supports on the table saw. You're right, it would have been great of Niall Barrett to include some info in his book on how to cut these!
Thanks, again.
Joe
Joe,
With some careful layout you could use a jig saw. If you are feeling more ambitious a backsaw would do the trick.
Enjoy.
