NuCraft comapany out of business?
I have a NuCraft cast iron extension wing router table that I bought from woodcraft supply 2 years ago. It was on clearance and came with an earlier version of insert plate (no leveling screws). I’d like to purchase one of the better insert plates or maybe the cast iron insert plate with reducing rings that they used to market through HTC. Apparently they are out of business. When I try doing a google search all I get are some old links to some of their products through Amazon.com. Is anyone using a NuCraft table out there? I’d like to know too if any router lift systems would be compatible with their oddball plate dimensions (10+15/16″ X 8+15/16″).
I have months researching this issue of the non-standard router cavity and have found no solution. I suggest that you look at Router Raizer (Model RZ100) which will allow you to machine the insert plate (drill holes) to meet your individual needs. visit http://www.routertechnologies.com
