Hello,
Ive been considering making another bench because I’ve outgrown mine and was wondering if a oak workbench top is a good idea? I really cannot see any pitfalls minus it being an open grain species of wood.
Any thought?
White oak would be as good or better than most hardwoods, personally I would not use red oak unless it’s quartersawn for the reason you mentioned, the growth rings would wear unevenly if flatsawn .
I think it would be fine if that is the wood you want. The medullary rays in oak are pretty.
I built my workbench out of white oak. The only issue I have had is the medullary rays tend to curl out and cause a splinter. Once they were all removed the issue went away.
My current bench top is a mix of red and white oak. 4 years in and so far, so good. The open grain hasn't been an issue.
I built my workbench with 100% red oak. top is 3plus inches thick. it is a good solid bench, no issues with the lumber at all! if you have the lumber go for it.the finish is 2 coats of boiled linseed oil, and it works and wears just fine.
Oak is perfectly fine-- It's heavy, hard, and fairly cheap. Spend no more time thinking about it. Build the top and get to work.
