Morning All,
My brain is not working this morning so I ask you guys:
I’m trying to layout an octagon on mdf, size 775 mm (30.5″), outside to outside dimension, and cannot figure out length of each side.
Any tips? Any tips for layout?
Morning All,
jackplane,
The geometry is no big deal but I'm not gonna try to explain it here. Lay out a square of 775 each side. Measure in 227 from each corner and that will give you the points of your octagon. Each side of the 8 sides should be = 321.
DR
DR,
yep, that's what I got. Thanks. Sometimes coffee helps only so much.
My normal tendency is to mess with the math to get a numerical answer. I replied that way several months ago to a similar thread. Someone else on that thread came up with a much simpler method IMHO. Use a trammel or beam compass to draw a 775mm diam circle centered on your MDF. Then put an accurate 45 deg. or combo square on the corners and put a line that's tangent to (just touches) the circle.
If you build it he will come.
If you have a lot to cut:
Cut squares 30.5" on a side. Put one on a crosscut sled with a corner over the kerf. It's exactly in the correct position when two diagonally opposite corners are each 15.25" (half the side length) over from the kerf. It might be helpful to draw a line there first. Attach a couple of blocks to the sled with double sided tape, touching the sides of the square furthest from the blade. Now, with no measuring or marking, put each square against the blocks and cut off the corners.
How to lay out an octagon any size octagon:
From a square of side length X, find the length of the radius that circumscribes the square. This is the distance from the middle of the square to a corner. Call it Y
From the corner of the square, draw a circle of radius Y and mark where it intersects the sides of the square. Do this at all four corners.
Draw lines from mark to mark, across the corner. You'll end up with an octagon inscribed in the square.
The math to calculate the length of the side of the octagon escapes me at the moment.
Jack,
Rather than repost - here's an old link asking the same question.
The drawing that I've put up there is the way that I was trained to do it. If accuracy's not critical, I'd use a tape to transfer the measurement
http://forums.taunton.com/fw-knots/messages?msg=9961.11
Cheers,
eddie
AutoCad makes this stuff easy - lol.
When I have to do octagons I go here and enter 1 measurement, neatest little thing you ever saw. It's an octagon calculator.
http://www.members.cox.net/ultimate_poker_table_top/Octagon%20Layout%20Calculator.html
