In the Reader’s Gallery I often see a piece is finished with “oil-shellac” Just what does this mean? Is it just a shellac finish applied over an oil finish? I use Sutherland/Welles Polymerized Tung oil for finishing a lot. Builds up to a nice finish and is easy to apply. After a can is opened better use Bloxygn (SP) the oil jells in the can quickly. I was looking at a 1979 FW mag and a suggestion in there for keeping oxygen from getting to an opened can of Tung Oil was to use propane from a torch to fill can. Don’t know about that helpful hint.
My polymerized (sp?) tung oil gelled - - and someone on knots suggested filling the can with water to eliminate the air. I'll try it when I buy a new can
To prevent tung oil and similar products from gelling in can after being opened, get a product called BLOXYGEN. It is a completly inert gas environmentally friendly yada yada. Before can of finish is closed give it a short puff of ol Blo and it will stay liquid forever. Rockler and others stock it. Rockler's cat # 39562. About $10 a can but a can will last a long time. Much less mess than trying to fill vacant space with water. I don't make a penny off the stuff it has just been my experience that it works. I understand that it works well on a partially emptied bottle Mad Dog wine also.
Thanks Mark, I'll use it for my wine.
"...partially emptied bottle...wine..." I have never heard of this. How does it happen?CharlieI tell you, we are here to fart around, and don't let anybody tell you different. --K Vonnegut
The best finish I ever got on Cherry was :
1) boiled linseed oil
2) orange shellac (dewaxed) 2 lb padded
3) 3 coats of 1 1/2 lb white shellac padded
4) pastewax
Frank
"Oil & shellac" usually means shellac over oil, but there is one method that actually combines them. It's described in Tage Frid's book, where it is called the 4-F ("Frid's Fast Fine Finish"). Basically, you wipe on a coat of oil, then brush on a coat of shellac; let sit until tacky, then quickly rub off all the excess with steel wool. I've done it, and it works - you get an appearance comparable to multiple coats of oil, in a few minutes. You can then wax it and be done, or pad on more shellac for a gloss finish.
"Everything should be made as simple as possible, but no simpler." A. Einstein
http://www.albionworks.net
A bit of an off topic question for you here, but you have some experience with the product. I think that Sutherland/Welles or Garrett Wade claims the product is useful for floors. My floor is a 150 year old poplar floor. It's not a hardwood. You see any advantage in spending the extra money and using this product?
