Hi All,
I’ve got a pair of PC nail guns and they came with teeny tiny oil bottles. I did a bit of searching around but know “this” is the place to ask. The question….?
What is this oil and where can I get a larger quantity? I read that it’s important to use the correct type with nail guns. I’m not using the nail guns daily but I rather buy a bunch now and know it’s on-hand.
Thanks in advance! — Fred
They sell pneumatic nailer oil. Senco is readily available at any of the big box stores.
Buy bigger bottle at your friendly home center. Should be right next to air guns, nails, etc.
Hi,
Thanks to all for the pointers. My next trip out there I'll take a look. During a kitchen renovation, there's quite a frequency of trips the those stores...
Kind regards - Fred
I'd be careful as to which oil I put in which gun. Different manufacturers use different materials for the various seals and components in their tools. Oils that may be compatible with the materials used in one manufacturers tools may not be compatible with the materials another manufacturer uses. and this may lead to premature degradation of various gaskets and seals and such.
Hi Ted,
NOTED! And thanks. This makes a lot of sense. I'll see if there's a Porter Cable barrel (or bottle) of it available locally - otherwise I hunt the online stores.
Thanks again to you and all for your help!
Kind regards - Fred
Actually Fred, all that matters is that you use air tool oil. Regular oil has a high amount of carbon which will buildup creating sludge , causing weak performance then failure. A manufacturer's "recommended" oil is just a plain and simple marketing scheme.
As long as the the oil is formulated for air tools, I have never heard that one oil is any better than another, as far as degradation of the rings, etc. is concerned.
However, some years ago I was using my framing gun in cold weather (about 10 degrees), and it went kaput. Took it in, the service guy asked me if I was using "cold weather oil" (which I wasn't, since I didn't know there was such a thing). Switched over, and the gun worked fine.
I've been using this stuff since then, year round; I assume it is a little like 5W 30 for your car -- a thinner version of standard oil.
I got this info from a service center that only works on guns and compressors, so I assume they knew what they were talking about.
John Wooden 1910-
a thinner version of standard oil. I use ZOOM SPOUT?? Non detergent,, It is Paraffin based and Non-gumming.. Does not make it right.. If your 'gun' states a OIL to use.. Use IT! and keep the receipts to prove it when you have a 'GRIPE'..
