I hope I am in the correct forum. I have an old sears robuck 6 inch Jointer # 103.23320 it is in good condition except needs some parts to completly rebuild it. Could someone point me in the right direction for help thanks.
Bearings, belts, pulleys, nuts and bolts, knobs, and blades are typically standard industrial parts. Anything that was made only for that machine, the main castings, guards, height adjuster parts and the like are only available through Sears or, if you are lucky, fairly often as used parts on Ebay from someone who is partying out a machine. What parts are you looking for?
Old Sears Jointer
Thanks for the reply
parts I need are Cutter Guard # 21170 & # 21412 Fence assembly # 21140 & sliding guard hinge assembly sliding guard washer head screw # 539-24x1/4 sliding guard knob# 608 sliding guard washer # 21622
Thanks for any help at all
Buddy
Old sears six inch Jointer # 103.23320
Sliding cutter guard # 21170- # 21412-# 21811
fence assembly # 1.21140 sliding guard and hinge
Probably your only chance for finding these parts is on Ebay if you are lucky.
fence bolt lock
I have most ot the part but need the Bolt with the cone on the end that threads into the fence lockdown, May need to make it on the lathe craftsman 103.23320 6 "JOINTER
