John:
I think you saw out on Knots that I have a mystery plane, subsequently identified as a Sargent 409. I was missing the screw that holds the blade and cap to the frog, but I found a hex head today that will do the job until I find the real thing. So, now I am hot to get it tuned up.
The blade has been a bit abused. The cutting edge will have to be completely reground, and after I derust it, I’ll also have to lap it.
The question is this: It an old Sargent blade worth that much trouble, or should I buy a better blade? Make no mistake — I have no burning desire to spend money if it can be avoided. If that is a decent blade, I’ll keep it and tune it up. But, IS it a decent blade?
Edited 3/16/2007 8:45 pm ET by Joe Sullivan
Sargent used good quality steel for their blades so I would suggest that you sharpen and use it as is. By the way, I saw your original post, and I'm quite sure your plane is a Sargent.
Aftermarket blades have state of the art steel and tempering which probably means they are slightly better at holding an edge, but most of the gain in performance with these blades comes from their added thickness.
I have always used the original blades in my planes and felt that they performed well and that the aftermarket blades didn't vastly improve the performance in day to day use on ordinary wood. The fancy blades probably are justified for working with exotically grained and tropical woods that are challenging to work with.
John White
Edited 3/17/2007 5:37 pm ET by JohnWW
Thanks, John. Sharpen it I will. Happy to do it and not have to lay out more cash.
BTW the conclusive proof that it is a Sargent came u out of the rust of the blade today -- a blade stamp that says HERCULES Sargent Manufacturing Company. Do you know of anyplace that has date information of Sargent planes? I am curious as to how old it is.
Edited 3/17/2007 6:16 pm ET by Joe Sullivan
JOhn:Have hit a wee snag with my Sargent. I got it pretty well cleaned up, and was test assembling it when trouble reared its head. As you know, the frog rests on the equivalent of japanned slides cast into the sole and is held to the sole with two screws that go through long slots. When I tighten the screws, the frog will only sit tightly in a small range of the whole length of the slots. If I move the frog forward, and tighten the screws, it will slide back to its preferred location even as I tighten them down. This appears to be a problem because it appears that the spot where the frog likes to live is too far back to support the blade.I have not tightened down the bolt that holds the lever cap. Could be that will flex the blade into the frog, but it does not seem right.Any suggestions or observations? How can I make the frog hop forward?
Edited 3/21/2007 11:44 pm ET by Joe Sullivan
Joe,
I'm sorry for not answering you sooner, but I have been traveling. I think I know what your problem is, but I need to spend a few minutes with a disassembled plane to confirm this. I will get back to you shortly.
By the way, was the plane body painted green, with the blade painted a dark gold, with the name Hercules cast into the face of the lever cap?
John W.
Edited 3/26/2007 3:11 pm ET by JohnWW
Thanks, John.
The plane is painted black. There is no name on the lever cap, but the blade itself is marked Hercules and Sargent up near the top (con't be exact because it is in the workshop and it is pouring rain out).
Joe
