Hi,
This is my first post on this site. I have been lurking and picking up a lot of useful information here as I get started into this new hobby. I currently have an old Rockwell/Beaver 9in table saw, which is actually not a bad saw. the fence though is very poor. I could upgrade the fence with an Accusquare, but have to wonder if it is worth investing that amount on this particular saw. Looking at new saws, I could afford something like the GI 50-185, 50-220, Delta hybrid 36-318, Ridgid 3650 or Craftsman hybrid. They are all roughly the same price give or take. However, for the same amount, I have the opportunity to pick up a used Delta Unisaw in great condition, 80’s vintage, comes with unifence, 3 phase already professionally converted to single phase. Seems like an easy decision. Go with the unisaw and this is what I plan to do when it becomes available. My question is: I read a lot here and elsewhere that many of these older saws are better built then the new ones. What is considered to be older? Is 20-25 years considered to be one of the “good old ones” or is this a newer saw?
thanks!
There have been some ups and downs in fit and finish, but the basic design has remained pretty much a constant. My 1940'2 era Unisaw has a cast iron ring on the base, instead of sheet metal, and has a louvered door. But arbors and bearings are still available.Motors are also If the basic cast iron parts appear good, then everything else can be tuned up. Go for the Unisaw.
Nothing wrong at all with the Unisaw.. I feel they were downscaled from what they once were but they are still a good saw. There was a brief period when there was a problem at the distribution center. Seems they didn't want to stay on the transport system and a few were sent out with some damage. That problem got turned into some really nasty rumors about design flaws etc., none of which were true.
The new delta hybrid is a real sweetheart and a great space saver but you'll certainly have more saw if you go with the uni.
I'm curious about the conversion from 3 phase.. was it a motor and switch change or did they use a phase converter? Hopefully they changed out the motor and switch and its still have a 3hp saw.
If its a 5hp 3phase saw with a static phase converter you can expect to still get nearly 3hp out of the motor. If its a 3hp motor you''l be lucky to get 2hp out of it. On the other hand, if its a rotary phase converter you will get nearly all of the hp that your motor is rated at.
Steve
"You can either be smart or pleasant, I was once smart but now I'm pleasant. I like being pleasant better." Jimmy Stewart - Harvey
WhatKnot,It is a 3 phase 3 hp motor converted with a phase switch. That would mean a drop in power to about 2 hp. I'm just a hobbiest, so I think the difference should be much of an issue. There is potentially another option. A friend knows someone who has 3 unisaws. 1 3 phase, and the other 2 are single phase, who might be interested in doing a swap. He would get a second 3 phase which he would prefer, and I would get a single phase which would work better for me. The seller is still considering his options, so the whole thing is on hold for a while now which is OK with me. I am a bit low in funds right now I would rather wait a couple months.
I'd be leaning toward the Uni if I were in your situation...provided it's in good condition with a comparable fence, and you have the electrical requirements. All of the saws you mentioned are excellent and well suited for home use, however the Uni is a notch above in power and construction.
