I am currently building a center island for my kitchen and want the finish to be a linen/off white solid color without any grain effect. I do not want a painted apearance to the cabinet. I have seen this look in kitchen cabinets before and the owners have descibed it as a stain. I have also seen the effect I like with Milk paint with a clear top coat finish. Do you have any suggestions as to the stain products that I could use and where to by them to get the effect that I am after. Could you also recommend a top coat that would be compatible with the stain and will not yellow over time
Jack
In my message I neglected to mention that the cabinets are made from maple
jack
Jack,
This an interesting question. If you don't want to paint, the next choice is to use a heavily pigmented off white stain or glaze. I would check local suppliers like Sherwin Williams or Benjamin Moore to see if they have anything that would fit the bill. Also check out The Old Fashioned Milk Paint Company for white milk paint.
If you've never used milk paint a word to the wise; make a number of samples to get the hang of it. Once you've built up a few coats you can rub it back with a scotch pad to polish it and get an interesting surface.
To finish the surface one of the water soluble urethane's would be suggested. I know there are a number of brands. I'm sorry I can't be specific about which one though. I don't use them on a regular basis.
I have a question. Why don't you want to paint it? You could put a clear coating over the paint if that is the effect you are looking for. Just curious.
Peter Gedrys
Peter
Thank you for your response. The reason I was shying away from paint was my concern that chipping would occur. Would the clearcoat diminish the chipping if it were applied over the paint. It would certainly would be easier to spray on the paint and clearcoat.
Thanks again
Jack
Jack,
The way paints are formulated, it's pretty hard to chip them. The surface would need to see some fairly significant abuse for that to happen.
Concerning spraying the paint; it is much more viscous than the urethane top coat so you will need to have the proper tips for each. If you've never done it before (paint), do yourself a big favor and spray some practice panels first. If you haven't assembled it yet the interior plywood surfaces might serve the purpose.
When spraying a water soluble topcoat, be sure and scuff or lightly sand the paint first to provide tooth. Also, be sure and clean your gun thoroughly upon completion. The clear coat will provide a some wear resistance for the paint. I always like to think about future maintenance and the question I would ask is what would be easier to fix? Paint by itself is the easiest. If you do decide to clear coat, read the directions on repairability. There are usually phone numbers on cans for the purpose of technical information. Check with the manufacturer and ask about the nuances of their product. Weigh the pros and cons and let that guide your decision.
Good luck,
Peter
Peter thanks for your advise. I trust your judgement. I haven't assembled the door panel or the frames. I have sprayed the interior of the boxes with a urethane. I will let you know how I make out. I put a lot of work into these cabinets and didn't want to mess them up. Thanks again
Jack
