Currently have a 16″ Husky that might be due for replacing. Is Stihl still the gold standard for saws? Husky still seems to have wide distribution in the big box stores but I am wondering if Stihl has just better engineered their saws for things like the blade tensioning. Appreciate all you opinions. Thanks
I have used Stihls for years. No problems and great service. When I lived in the Shenandoah valley and went to a lot of tool auctions, used Stills went for close to new prices. The buyers were loggers and landscapers.
Huskys and other big box saws went begging.
From what I gather Still and Husqvarana are two of the best. I went with Husky because there are multiple dealers close by. But either would be a good choice from what I read.
I've had both Stihl and Husqvarna. Both are good saws but the stihl was quieter. That matters to me.. My friend the tree guy and chainsaw repair man is a little miffed at newer Stihls over a change up in carburetors. He still uses them though.
My research says Sthil and Husky are about equal, Echo being a close 3rd. I have a MS251, running a 18in bar, nice saw but my second saw was a echo cs-590. I went echo after the Sthil was in the shop for 3 months waiting on parts, for the second time. I got tired of parts only being available from dealers.
From a use perspective I don't find one better than the other, other than the echo is a bit heavier but also more powerful (it is a larger saw). I do like the tensioner being on the saw vs the cover. I would not hesitate to get a echo, husky or Sthil.
It depends on how much you are using the saw, and how big is the stock you are cutting.
If you aren't using it much, it doesn't matter as much what brand you get. I'd even suggest a battery powered saw. I have the Milwaukee, and like it. If it's going to get serious use, get a pro level Stihl. I have one of those too, and like it. But just to grab and make some easier cuts, the Milwaukee is more convenient.
Gas powered tools that don't get a lot of use get funky,then they are hard to start. Or won't start at all..I know, there's stuff you can do but then you have to do it. An electric might be the way to go if it's an occasional use tool. I used a Husky corded electric, it was a good saw,plenty of power. I ve considered buying one.
I use a Stihl but Husqvarna are just as good. Would be happy with either. very similar really.
Just about any brand will suffice if you use it occasionally on Saturday mornings. If you use is frequent and/or on BIG trees goes with a pro series. BUT above all else use a gas treatment faithfully. AND find a source for non-ethanol gas.
If you are not using your chainsaw frequently, use the pre-mixed Husqavarna gas. It's made with non-ethanol gas. Although expensive, I think it is worth it as I never have any trouble starting my leaf blower or chainsaw.
I no longer mix my own. The premix with ethanol free gas is superior.
