I’ve had really bad luck with my Bosch sander and
I’m ready to buy another but don’t know which is
best. I want a variable speed and one that has a good
surface for hook and loop sandpaper pads. The pads
on my current machines don’t hold the paper very well.
Ken
Popular Woodworking did some testing...see October 2001 issue.
Fein MSF 636-1 was rated the best @ $450.00.
If this is too pricey look at one of the others rated good quality..
Makita B05021K @ $110.00 Porter Cable333@$65.00
Porter Cable 333vs @$85.00 MakitaB05010@$70.00
MakitaB05020@$80.00
Edited 4/25/2004 11:57 pm ET by djhawk
Dovetail,
Based on your "headline" I thought you may have been inquiring about oscillating spindle sanders. Having read you post, though, it sounds like you're really asking about random orbit sanders. My little PC 333 has given good, if light-duty service.
I'm curious to know what kinds of problems have you've had with your Bosch - I've never had a bad experience with a Bosch tool.
-Jazzdogg-
The Bosch disk that holds the paper comes loose and
flys off. I've had it repaired and continued problems. Last repair
used locktite on nut and assured me it would never come off. Guess
What? Came off the first time I used it. Was expensive tool but I
don't want to waste more time and money with more repairs. I have other
Bosch tools that have been satisfactory but won't be looking to purchase the
brand in the future. Thanks for your suggestions
Here's the latest report card put out by Workbench.
Bosch model 1250DEVS @$300.00 was the editor's choice
Ridgid model R2610 @$170.00 was rated top value
Others tested include: Porter-Cable, DeWalt, Makita, Fein, and Festool....
See Workbench Magazine; June 2004 for the complete test results....
Personally, I use a DeWalt 443 and a Makita 5010. Both
cost about $85.00 and do the job for me.
Edited 4/26/2004 9:11 pm ET by djhawk
I had the same problem with my 3017EVS ??? (5" RO, with pistol grip, adjustable front grip and all plastic housing). Red bearing and stud-mount Loctite did the trick for me. I'm just curious what model you have because the pad on mine attaches with an allen bolt and you mentioned a nut. FWIW I compliment my Bosch with a Makita 5" single-speed palm RO. It's an excellent finishing sander where the Bosch is more aggressive for the initial grits.John O'Connell - JKO Handcrafted Woodworking
I have the 6" Metabo, and have no complaints. Strong, VS, 2 settings for the orbit (large or small), and excellent DC with a Fein Vacuum. It is less expensive than the Fein and the Festool, and an excellent machine.
Alan
Alan
http://www.alanturnerfurnituremaker.com
I abuse the heck out of my Mikita but it doesn't have variable speed.. I've got a varible speed but I like how rugged and quiet my Mikita is and find I use that all of the time.. probably sanded well over twenty thousand bd.ft. with the Mikita so far,.. mostly white oak and black walnut.
It also is a bit smaller and lower so it seems to fit my hand better. I find with others I've tried they don't seem to feel as nice..
I have the PC 333...actually, I have two of them. My dog ate the dust collection cannister on the original and since the part was backordered, hey, opportunity! Now that the dust collection cannister came in for the old sander, I no longer use that method of dust collection...I hook up the dust collector directly to the sander for a much cleaner shop. Having two sanders is great when sanding a bunch of boards in sequence, say, from 120 to 150 to 180 to 220 to 320 grit. Other times I keep both sanders on the workbench, one with 120 grit and the other with 150 grit, to knock sharp edges off or sand down wood plugs.
You can find this tool (and others) at a really low price if you go to http://www.toolseeker.com
Woodworker's Supply has it for about $50, including shipping.
