Bought a small can to test out. Anyone have any good or bad experience using it? Can it be applied over an existing wipe-on oil? Appears to be a good tabletop finish..
I started using it a few years ago and it has become my main finish. I have no dedicated finishing area so dust can be a problem when doing finishing in my shop and Osmo is relatively impervious to dust because it is a wipe-on, wipe-off finish. My experience is that it is good for stain resistance and is easily repaired. I am also using Oli Natura Hard Wax Oil and I think I like it better than Osmo.
I put a homemade BLO/Mineral Spirits/Poly blend down as my first coat in every case I'm not using WB finishes. That said, I often use hard wax oil over top with no problems.
I started using it and it has become my "go to" finish. It is easy to use and leaves a wonderful feel on finished wood. Here is what I've learned about it.
One coat is enough on furniture.
A second coat doesn't add much and is hard to get right.
I apply it with a white scotch pad.
A little goes a long, long way.
It dries clear and smooth over epoxy.
It's expensive, but worth it.
I use clear, extra thin 1101. Try it, you'll like it.
Thanks for all the good replies. Now running a few test pieces and liking the results. Agree with the one coat only -- does seem to save much finishing time.
I recently completed a walnut storage chest and used the OSMO Polyx product with great results. I applied two very thin coats using the techniques described in this article:
https://www.follen.com/osmo-polyx-for-walnut
I'm very pleased with the results and amazed at how much less tedious it is to use and apply than my typical Minwax Wipe-on Poly.
Thanks!
Recently completed five walnut dressers and used Osmo.First after sanding sealed the wood with a light coat of shellac .Light buffing then a coat of osmo rubbed in with a orbiting sander with a white 3m pad.After a "while" rubbed it down with a clean lint free cloth.Plywood components sometimes wanted a second coat probably due to the way the veneer was sliced.Good by Watco,Oil and Wax ,etc.etc.
