I been asked to make an outdoor sign for a friend’s cabin. It would be about 30″ x 20″ and probably painted, cut into the shape of a bear. What wood would be best? Also is there a recommended thickness. The sign will be in Michigan so it will see a range of weather. Thanks George
Dear Midwood,
I'm no sign-painter (we lefties have trouble with sign painting), but I did edit an article not long ago for Fine Woodworking about carving letters. The author has made most of the signs for the factory outlets in Freeport, Maine, so I think he's pretty authoritative when it comes to outdoor signs in areas of serious winter weather. Basically, he uses just about any good straight-grained wood. Could be pine, poplar, mahogany, maple. The species isn't critical, so long as the wood is well finished on all sides. Prime and paint, or seal with shellac, then varnish. If you have to join boards together to make the sign, use a waterproof glue.
Hope this helps.
David Heim
Managing Editor
FineWoodworking.Com
David, Thanks for the info on wood for signs, it gives me a larger range of wood than I originally thought.
Best of luck
