Hello All,
I am planning on building an outside woodshed that I will be keeping cut, split wood for my fireplace as well as drying wood for woodworking. I am wondering if anyone out there has built anything like this in the past. I have a lot of ideas as to how I will tackle it but am always willing to listen to others. If anyone has pictures of anything they have already built that would be great or if anyone can direct me to a website that may have pictures of these structures that would also be appreciated. I am planning on it pretty much having open sides to allow for air circulation. Any opinions or advice would be appreciated.
Buzzsaw
Try the US Forestry Service website. Look in their publications sections and search for drying hardwood lumber or drying lumber.
for drying lumber....you need to follow 2 principles.
1. allow air circulation around faces and edges of ALL boards.
2. protect from direct exposure to the elements.
Shed is great for #2. Normally terrible for #1.....getting air circulation through an enclosed building normally requires a motorized ventilation system. Hence, most air-drying sheds are simply roofs held up by posts...no walls.
On the neverending quest for wood.
I did one years ago and it's held up really well. I used standard framing and covered it with bevel cedar siding. The one thing I did that was different was that I used 3/4" spacers behind the bottom of every siding board (you can use nails that are sticking out 3/4"). This gives good air circulation, but keeps the wood dry and looks good. I also covered the floor with old pallets and installed large gable vents, again to promote air circulation.
Jim,
do you dry green lumber in the shed or store lumber that's already below 20% MC? Just asking for future reference....I've never tried drying lumber in an enclosed shed but offered the above thoughts simply based on reasoning.Tim
I only use the shed for storing firewood, which goes in as soon as it's cut in the spring. By the following winter, it's ready to burn. btw, I located it to get a lot of sun. It's never occured to me to store lumber, but now that you mention it...
Jim,
Is there any way that you can post a picture of what you built?
Buzzsaw
Buzz, perhaps a tad extreme for your needs, but the concept may work for you. These structures have shown themselves to be quite robust, and are quite easy to build.
This one has the arches set upon a 4' knee wall to ensure sufficient height - a requirement not likely required in your case. Tighten the arch spacing will improve snow-load capabilities. Many are built with ply front&back, and I've heard of some using ply in lieu of plastic for the roof.
here you go. it's a pretty poor picture, but hey, it's a woodshed. i also tried to do a crude sketch of how i did the siding. my drafting skills are not good
I grew up in Northern Ontario, Canada. The shed we used was made standard frame and sided with sawmill slabs. My brother-in-law's woodshed is just poles sunk below the frost line (spaced as far apart as beam supports would be) strapped again with slabs. Both sheds have been standing for >10 years. I guess a lot depends on if you'll see the shed and thus need it asthetically pleasing or simply need a place to dry and store wood...also how much money you got.
Good luck. Chris.
