I want to lay out an oval top for a dining room table. I vaguely recall seeing an article in the magazine showing layout techniques for such tops but can’t find it in the archives. I am interested in doing a veneered top with a hardwood oval border but have no idea how best to layout such concentric ovals much less how to get a clean router cut that will allow me to join the border to the veneered top. Any guidance?
Hi Peach,
We have a few articles that should get you through this project, so I'll start with a few links. Let us know if you get stuck along the way.
Table Design: Graham Blackburn wrote this great article on table design. You might be past the design stage but I recommend reading it before you begin any table project.
Drawing Ovals: This article shows a shopmade jig for drawing an elipse. If you build a sturdier version, you can attach a router to it rather than a pencil and cut the outside perimeter of the veneer core. (Here's an article with tips on routing with a tramel jig.) Even easier, you can use the pencil version to produce a router template (1/4 or 1/2 section of the elipse) to guide a bearing-guided router bit.
Matching the hardwood edge: This can be tricky because the outside curve of the table is going to be just a hair different than the inside curve of the trim. Don't fret, this article offers a fool-proof technique for producing perfectly fitting hardwood trim. I've tried it and was amazed how precise it was.
Best of luck,
Matt Berger
Fine Woodworking
Thanks so much for this advice.
