I recently read Fine Woodworking’s “Designing and Building Cabinets,” and ran across a reference made by writer, John Green, regarding an “overhead router made from scraps of plywood.” If anyone knows more about this fixture, please post.
Thank you, Tang
I don't know about a jig, but a Shopsmith router is, in effect, an overhead router.
Go to "http://www.newwoodworker.com" and look under plans for adjustable router guide. Good Luck. garmtn
Google on the subject. Popular Mechanics had one on their site. Vertas makes an arm with the pin on the arm and utilizes a plunge router below with a lever to move it up and down. Grizzly sells a couple including a bench mount model. Delta used to sell a couple including a smaller Onsrud bottom mounted router. FWW had a very small article years on on overhead routers but barely touched upon the subject. I've used big ones extensivley in large factories and unfortunatel there is little documention on using these. Typically it is learned hands on with previous operators giving the ins and outs of this amazing, versatile machine. largely replaced by CNC but still a viable option in the small shop. Different sized pins with the same sized bit will yield carying sized rabbets and they are especially good for template work on copying patrs with master patterns. Especially good for tight curves and internal shapes that would be difficult to do other ways.
Thanks everyone for your tips. The most informative link regarding overhead or pin routers was the Popular Mechanics article suggested by RickL. Here's the link for anyone who's interested. http://www.popularmechanics.com/home_improvement/workshop/1274466.html
Tang
http://www.grizzly.com/products/mach-specs.aspx?key=560020
Unfortunately there is little to explain the virtues of this machine. I picked up a Wood Tech version of the medium sized pin router for $200. I've got an English book on machines that gives some information on pin routers but nothing too deep. I have a bunch of old vocational text books and those are prtty lame as well in general on machines.
Try to imagine, say a 1" router bit and the effects of using different sized guide pins and different depths to get some idea of the possibilities.
