I am soon to start a project calling for extensive use of oyster work. I got the job based on a small sample panel, but I know I would have difficulty with the large cabinet called for here.
Does anyone have experience with oyster work they would be willing to share?
Any ideas about references or books on the subject?
All suggestions would be appreciated.
Hogwood
Just curious,what is oyster work, I haven't heard that term.
mike
Mike,
Imagine taking a smallish log (often a branch) a couple inches in diameter and cut across it at an angle (closer to 45 degrees than 90). The cross section will have a shape similar to an oyster shell. Chosing the wood carefully will reinforce the image of a shell, especially if there is good contrast between the sap and heart wood. If you cut a bunch of these cross sections thinly, you can inlay them onto another board as a decorative accent, main design feature or use as a veneer. In the March/April 2004 FWW there was a good article with an awesome picture of this technique and how to do it.Here is one picture I found on the web, it is not great but gives you the idea.
http://www.furniturebuying.com/pages/construction/veneer.shtml
Thanks, learned something new today.
mike
It seems that some of the FWW technique books and back issue can help you with this. I found this site http://www.xs4all.nl/~stremen/fww.html that listed what was in the index of all the FWW magazines. If you hit ctrl F in your browser and search for the word oyster, you will be able to find the back issues that cover the technique. Apparantly, several books on veneering and/or marquetry also cover the technique, I saw that when I did a Google search.
Thanks for your tip. I need all the help I can get.
FWW issue #169 has an article by Silas Kopf on resawing oysters, which covers some of the process and has a few nice photos of example work.
Here's a link to the page where you can purchase the back issue if your interested: http://www.taunton.com/store/pages/fw_toc_169.asp
