The last posting I put on was question about how to stablize spalted maple so that it could be worked across the grain. I got some very helpful replies. Thanks very much to those that offered their advice.
I have some screens in my house that are made by stretching wet handmade paper over a frame , locking it in place to stretch it, then putting on a few coats of laquer to make it semi transparent. The problem is that these screens are “very”fragile. Is there a better material to coat them with, or, how do I make them more duirable?We like the effect of the paper, and the translucency of the screens.
I would appreciate any help you can give me.
thanks
bob
Thinned white glue, or thinned yellow glue for a darker shade, should give offer a little more strength than lacquer which is brittle. In this way, the glue acts as sizing.
I used paper in the first screens that I made. It looked great but only took a un-attended child about 10 seconds to tear them all out while a realtor was showing the house..
After that I ordered some material from Japan Trading Co. in San Francisco.
When I moved into my current studio 20 years ago, I made them for the front windows which are 24' long. they still look good, and none of them have been torn. It looks like shoji, but is a lot like lamp-shade material. I'll bet you should find lots of that kind of material on Google.
To answer your question though, I thought you were to use watered down white glue. You might try gluing the paper onto the shade material if you don't like the other suggestion. good luck
Thanks for the suggestions. The reinforcing idea sounds good to me. We'll give it a go.
Bob
Bob,
You are looking for Shoji-Gami paper. This is a traditional material used in making Japanese partitions and screens.
Lee Valley actually sells a roll of this paper for use with their Japanese calligraphy set. It is 11" x 60'. http://www.leevalley.com/gifts/page.asp?SID=&ccurrency=2&page=45108&category=4,104,45468
You should also look for a 0.45mm thick laminated rice paper.
Do a search for Shoji screen manufacturers in your area, you should be able to purchase paper from them, or point you in the right direction.
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
I completed a project earlier this year for a downtown hotel that called for a series of 10 shoji screens each 8'x8' overall, made up of three 32"x8' panels connected with bidirectional hinges. I couldn't use paper (fire code, durability) so I used a transluscent fiberglass fabric. However, unattended children aren't the only problem. Banquet staff, exhibit contractors, musicians, inebriated banquet guests, sober banquet guests, and any of a host of others are responsible for the callbacks to repair torn and punctured fabric.
I've toyed with a couple of solutions, but the best one is to add a piece of thin transluscent acrylic plexiglass to cover the entire back. While it would increase the weight by about 15%, it would also add rigidity while making the fiberglass fabric nearly puncture-proof.
Here's one resource in the Chicago area for the fiberglass fabric...
http://www.eagerplastics.com/shojiscreen.htm
tony b.
