I am building a bookcase and was curious as to what the best type Primer/Sealer & Paint combination would be for a smooth & durable finish?
Thanks.
Thanks.
There is an article in last month's Fine Woodworking about preparing and painting a surface. Check your library.
So there-
There are two articles about painted finishes in FWW. Dec 1993 "Paint Grade Cabinets" and April 1995 " Better Painted Furniture". I finished a piece with the method in "Paint Grade Cabinets" and it came out great. My e-mail is correct in my profile. If you want either of these article let me know and I'll scan them and e-mail them to you.
Joe
I do a lot of kitchen cabs, and have found that the Sherwin-Williams Pro Classic 100% Acrylic is a durable and washable finish. I usually shoot two coats of primer, the first sanded, and 2-3 coats of finish. Water clean-up. Brushes and sprays well, but will need thinning. Give it a week to "cure." Available in many colors.
Stay away from regular latex, as it will "block" under heavy loads such as books.
do a lot of kitchen cabs, and have found that the Sherwin-Williams Pro Classic 100% Acrylic is a durable and washable finish.SW also makes a product called Blending White Conversion Varnish which is tintable in light shade pastels and such. I use it exclusively. It requires a catalyst and likes to have catalyzed vinyl sealer under it. All my painted kitchen cabinets get this treatment and I find it durable and very smooth to the touch. Nearly bulletproof around things that would stain some other finishes like wine, tomatoe sauce, and the like. Aloha, mike
Thanks for the info. I've used CAT and conversion stuff, but I like the ease of use and clean up of WB.
I usually like to give the HO a kind of finish that they can repair or replace themselves. Most of the cabs I do have painted carcases, with slab or F&P doors. Not high-end. They can repaint the cabs, and refinish/replace doors to their liking after a few years. Never had a problem with staining.
How will you apply the paint (brush or spray)?
Website
I've had luck clear coating the painted surface with water based poly. First I did it because I was covering a stenciled pattern in pastel children's pieces, but I found I liked the harder finish so I do it on all painted surfaces now.
