I was going to build a combination bookcase and drawer wall unit for my bedroom. I was planning to use mahogany with a clear lacquer finish. Subsequently the Bedroom Design Authority decided they wanted a painted finish. So, given that the unit is to have a painted finish, I will use some wood other than mahogany, maybe birch or some other strong stable wood that takes paint well. Any suggestions?
Also, for the mahogany design I was planning to dovetail the case sides to the top and bottom. I still want to use through dovetails, even though they will be painted over, to preserve the structural rigidity. Since I will be painting end grain (dovetail pins) will I still be able to get a good finish where the dovetailing is not visible?
There are other joints that will provide the structural rigidity you need for the cases. The casework dovetails would still be visible under the paint; but this more muted appearance might just suit your taste.
You don't say if you are planning to make the cases out of plywood or solid lumber, but I assume the latter if you are going to dovetail the joints. If so, either poplar or soft maple would be a good choice.
Also, if your plan is to dovetail the cases, I assume you will also dovetail the drawers. If so, you might consider using a natural finish for the drawers -- especially if you going to have false fronts. Painting the fronts and varnishing the drawers is a look which you might like in this sort of application.
Don't think I want the dovetails to show through the paint. I always felt that dovetailing a case joint was always the strongest joint. What else would be as adequate?
I do plan to use dovetail joints and a natural finish on the drawers. Will have frame and panel false fronts (painted) and the drawers will be inset.
I always use a locked rabbet on plywood case work -- strong as all get out, and invisible from the sides.
I would recommend using plywood for the cases, unless you have some compelling reason not to.
Not sure what a locked rabbet is. These units will be bearing a lot of weight. Will plywood joints be strong enough?
Easy to draw, harder to explain.
Think of it as 1/4" dado in the case side, with a 1/4" tongue on the case top/bottom.
Does that help?
Yes, I think I know what it would look like. Thanks.
jack,
Most folks like poplar for painting.
How about half-blind pins on the case ends? Dovetail the top down, and the bottom up.
Cheers,
"Most folks like poplar for painting".
I have tried using poplar before on my kitchen cabinet doors. It did finish nicely but I had terrible luck with warpage. I wound up using solid birch for the cabinet door frames and MDF for the panels. Both materials took the white enamel finish very well. Anyway, I have since avoided poplar but maybe I should try it again and give it several weeks to adjust to my workshop before attempting to work with it.
Using only quarter sawn stock will also make a difference.
