I have some old oak cabinets that I am trying to refinish. They have been painted at lease two different colors. I wanted to try and bring back the oak look. My question is how can you get the paint out of the grain of the oak without sanding? I am afraid if I sand them I would have to sand very deep to get the paint color out. If I tried to stain the oak would that cover the color?
Irishpapa
Tell me about the wood. You elude to cabinets but are they solid or veneer.
Steve - in Northern California
Steve
They are solid oak.
Dan Jackson
The brass-bristle brush technique is the only way I know of to get the crud out of open grain. Just keep recoating with stripper and scrub the stuff out. Buy a bag of the brushes. You will need to replace them often. Good luck.
Does the surface appear to be smooth and glassy or is it porous feeling?Steve - in Northern California
Removing paint from oak pores is a chore. Here's your choices;
Apply a semi-paste or paste stripper and let it sit for a while. Then use brass bristle brushes (you'll need more than one) to scrub the paint from the pores (without removing the stripper first).
Same stripper - use round tooth picks to get the pores one at a time.
Same stripper - use full body protection - after the stripper softens the paint in the pores, use compressed air to blow it out. I know this sounds insane, and I guess it is a little, but if you have the space (flying stripper) it works.
After stripping - do an after strip wash with lacquer thinner and let the wood dry for a day. Apply a good coat of shellac. Let it dry a day. Use the stripper again to remove the shellac and the paint that bonded to it. If this does pretty well, a second go will do better. Sometimes the paint and shellac don't bond.
Take the cabinets to a strip shop with a flow over system and let them scrub the paint from the pores. This should probably be the first option!
Bruce Johnson's book "The Weekend Refinisher" is a good reference for refinishing and may offer some additional tips.
Paul
F'burg, VA
