i am going to paint some of my newly made kitchen cabinets white. any thoughts on using an outdoor trim paint-i’m assuming it would be more durable. the cabinets are burch plywood with poplar face frames and doors. thanks, bill
If the outdoor trim paint is a latex that may be a bad idea. Exterior latex does not get very hard when cured an therefore can not be scrubbed clean. Interior paint does achieve a harder film and can be clean much easier. However even if you use an interior paint you may want to top coat it with a waterborne clearcoat, which will get even harder than the paint.
Ron
Edited 8/1/2006 9:55 pm ET by Ronaway
thanks ron, by clearcoat do you mean something like minwax waterbased poly.bill
The Minwax WB Poly would probably work, but you may want to try some samples on scrap to verify compatability. I am not a fan of Minwax products. I think they get away with selling low quality products because of good advertising. I would suggest you talk to Jeff at Homestead Finishing and see what product he suggest that you use on the cupboards. There are a lot of good cabinet finishing products that can be purchased with the white color already in the product.Ron
ron and howie, thank you very much bill
For durable and easy to clean surface, I strongly reommend a good oil based enamel paint. A primer and two coats will give you a very good finish.
The main difference between exterior and interior paints is that the exterior contain additives to protect the paint from the UV in sunlight. Used indoors, a exterior paint offers no advantages.
thanks for the response, would you brush or roll on paint. if you would roll any sugestions as to the type of roller
If you use an oil based enamel paint, no clear coat is required. In fact, a waterborne clear coat is not as durable as an enamal oil based paint.As to application, I'm partial to brushing. Rollers do not leave as smooth a finsih. Thin the first coat 25% with mineral spirits. Apply with long even strokes. Use a good natural bristle brush. Let the first coat dry two days and then sand it flat with 320 paper on a sanding block, sanding in the direction of the grain. For the next two coats, thin the paint about 10% for better flow out or leveling. Do not overbrush.If you are not comfortable with your brushing skills or techniques, practice on some scrap or on some cardboard boxes.Howie.........
