Recently I turned a new leg for a friends spindle bed. The headboard has been dinged up pretty bad and I suggested painting. It has an old stain on it now but he said they will sand that down. What would be a good brand/type of paint to use?Does it have to be sanded down all the way to bare wood? Hope someone can help……………
It does not have to be sanded to bare wood, but you need to clean it first with a wash coat of mineral spirits to remove any traces of wax or silicone. After the wash coat, lightly scuff sand it with 180 or 220-grit paper. Wipe or blow the dust off then wipe it again with a rag soaked with thinner. After that you can prime it with an oil-based primer/sealer and then apply the paint of your choice after the primer dries.
*Thanks for your reply. But now I have another question. If he uses an oil based primer,does he then need to use an oil based paint?Also,do you have a favorite brand of paint that is easy to apply and looks good?One more,when I apply certain finishes I use a foam brush to keep the brush marks to a minimum. Can you use foam brushes w/paint or do you even need to??Thanks again.........
*In answer to your three questions:1)No, but I would because I prefer the way it goes on and sets up.2)For furniture and trim--Benjamin Moore semi-gloss alkyd enamel. (But other brands are good too--Pittsburgh, Pratt&Lambert, Sherwin Williams, etc.)3)Foam brushes work great with oil-based paints and finishes.
